Ford Fiesta 2011 AdvanceTrac Issue
davefollmers
Anmeldungsdatum: 25.01.2018
BeitragVerfasst am: 12.03.2018 09:09    Titel: Ford Fiesta 2011 AdvanceTrac Issue Antworten mit Zitat
HI,
The advancetrac light pops on when I turn to the left..BUT not all the time..its very intermittent, sometimes its pops on when i am driving very slow..and it happens only when turning left..so when it pops, the batt check and the oil light also pops on but it disappear after a few seconds.When it pops, the car when slow and reduced its power and sometimes the engine turns off..There is also a case when the check engine light turns on but disappear after 2 days..This started to happen when I ran over a rock with my left front wheel. The incident broke my tyre.Based on my readings, it can be wheel speed sensor error or wheel bearing, i am not sure.Hope you can advice.
please help
I did not find the right solution from the internet.
References:
http://forscan.org/forum/viewtopic.php?f=5&t=4438
Thanks
